Results 1 to 4 of 4
Thread: Shock vs Bleach
    Illinois
    Default Shock vs Bleach
    Trying to get an understanding of bleach vs. shock. I use both. Does that make sense. Actually I use bleach, shock and pucks in my chlorinator. Does shock do something more than the bleach does?
    mas985's Avatar
    Pleasanton, CA
    Default Re: Shock vs Bleach
    Quote Originally Posted by ksturge
    Yes, it costs you more . All you really need is Liquid Chlorine, AKA: Bleach. To shock your pool just use more. To chlorinate your pool, use less. Dosage for shock or chlorinating can be found here:
    http://www.poolforum.com/pf2/showthread.php?t=365
    Mark
    prh129 is offline Lifetime Member Widget Weaver prh129 0
    Rehoboth, MA
    "Shock" means to raise the chlorine level past the breakpoint which forces a chemical reaction that gets rid of combined chlorine (CC). This point varies depending on your CYA level - the higher the CYA, the higher level of chlorine needed to reach the breakpoint. Ben's best guess chart will give you an idea of CYA vs. chlorine.
    There are products labeled as "shock" but it is just concentrated chlorine to boost your Cl level up quickly. If you add enough bleach (look for the BleachCalc program from mwsmith2), you will reach the shock level too.
    Peter
    waterbear's Avatar
    St. Augustine, Fl
    Think of 'shock' as a verb...something you do, not a noun.
