Thread: Solar mat
    Default Re: Solar mat
    Many people do use solar panels and they do add a lot of heat. One of the other moderators lives in NE Pennsylvania and he uses panels. I've been in his pool when it was too hot -- 90 degrees -- as a result of those panels. So, yes, I think they could help you. I don't live in a place that has such cold winters as he does, but I still store my solar panels inside our shed to protect them. The best thing to do is to use the panels and also a solar blanket on the pool at night to keep you from losing heat overnight. Those two things together will make quite a temperature difference for most pools.
    As far as good reading material ----- read a lot of posts here on the forum and also on our sister website www.poolsolutions.com and I think you'll get all the information you need to help make taking care of your pool as easy as possible.
    Welcome to the Pool Forum!
    BigDave's Avatar
    ...too hot -- 90 degrees -- ...
    Not!
    My pool's been 94 for the last 4 days (the solarcontroller's set for 95) and I LOVE IT!. Solar panels and blanket work great for me!
    That's hotter than I like for swimming in the daytime. When it gets too warm, I don't think it is refreshing. But, for night time swims, a little warmer is fine. (Currently my pool temp is around 90-92 I think --- too warm ----but we have also had a week of 100 degree temps. it is currently 101 as I type this.)
    You're kidding!! ????
    Quote Originally Posted by trinitysite View Post
    Also, is there any good reading book materials on swimming pool? The only one I came across which I liked but a bit too technical is "The Ultimate Guide to Pool Maintenance" 3rd edition.
    Unfortunately, no. I have that particular book, and it has MANY serious errors. (So do all the others I have!)
