Results 1 to 4 of 4
Thread: Nature2 Pool
    Jul 2012
    LA
    Default Nature2 Pool
    I have a 28,000 gallon pool with Nature2 filter built one year ago. This was recommended to me by our pool builder (as opposed to having a saltwater system). I had terrible scale buildup over the first year, at least that's what I would call it. Just abundant white, chalky flakes of material in the pool. The guy who services my pool thought it was do to the type of chorine shock I was using which had calcium in it. He recommended I switch to another type of shock; so far that has improved things a bit. Has anyone ever had this problem with a new pool? What is your experience with a Nature2 system? Thanks for your advice!
    Default Re: Nature2 Pool
    Hi Dawg,
    You won't find any Nature2 fans on this forum. Nature2 uses copper and other minerals to supposedly prevent algae from growing and allow you to run lower chlorine levels in your pool. What it actually does is add enough copper to your pool to create staining conditions (copper is what turns blonde hair and fingernails green, not high chlorine!) and compicate the water chemistry, and may or may not kill bacteria, but does not kill viruses. So...while you may be able to run lower levels of chlorine and not have algae growing, you will not be able to run lower levels and keep the pool sanitary enough for me to be comfortable swimming in it.
    You can use the google link in my sig to search the forum for Nature2 users who have posted. You will find lots of results, but very, very few of them will be positive. Until your registration is upgraded, you'll have to log out to read the search results, but that's a temporary inconvenience.
    Odds are that the white scaling was calcium, but without a set of water results, taken with a drop-based kit, as well as a list of what you've been using in the pool, it is impossible for us to do anything but guess. I doubt it had anything to do with the Nature2.
    Welcome to the forum!
    Quote Originally Posted by Dawg85 View Post
    I have a 28,000 gallon pool with Nature2 filter built one year ago. . . . . What is your experience with a Nature2 system?
    We don't recommend Nature2 units, but it's unlikely that your unit had anything to do with the pool problems you're having. Do this:
    1. Complete the Pool Chart, so we can tell what you have:
    Pool Chart Entry Form
    Pool Chart Results
    2. Get a good test kit -- 'guess-strips' don't count, no matter WHO reads them or HOW they are read:
    + Get a cheap OTO (yellow drops) / phenol test kit, or if available at YOUR Walmart (check availability), get the HTH 6-way DROPS test kit, which is compatible with the Taylor K2006. Test the pool as soon and you can, and post the results. If you get the 6-way kit, ALSO test the water you FILL the pool with, especially if it's a well, and post THOSE results as well. (The HTH is the best available kit you're likely to find locally, but it's not the K-2006. It can only provide rough measurements chlorine levels above 5 ppm, and it measures "TOTAL" hardness, rather than "CALCIUM" hardness, which is not ideal.)
    HTH 6-Way Test Kit @ Walmart
    3. List the chemicals you've been using over the last 2 months, by EXACT pool chemical name and EXACT brand. (Similar sounding chemicals can have VERY different ingredients and effects.)
    Jul 2012
    LA
    Thanks so much for your advice. much appreciated!! Dawg85
  1. standard, salt or nature2
    By gcurrlin in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-10-2012, 02:33 PM
  2. Saltsystem? Nature2?
    By oroepke1 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-09-2010, 12:52 AM
  3. The Great Nature2 Debate
    By CarlD in forum The China Shop
    Last Post: 06-27-2010, 11:28 AM
  4. Chlorine pool and the Nature2
    By BUCKEYEPOOL in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-12-2010, 01:00 PM
  5. Nature2 Purifier?
    By Calicowinks in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-04-2006, 03:59 PM
