Results 1 to 10 of 13
Thread: next steps for well water pool?
    Jul 2012
    Illinois
    Default Re: next steps for well water pool?
    A little more info:
    Evening of July 7 -added 2 gal bleach
    Morning July 8 -tested with the HTH drop tests
    Total chlorine 3-6
    pH 7.5
    Total alkalinity 350
    Total hardness 360
    Evening July 8
    total chlorine 0
    ph 7.8
    Well water:
    Total chlorine 0
    pH 7.8 (at least)
    Total alkalinity 430
    Total hardness 360
    Cyanuric acid- not tested
    Anything else I should do? Thanks
    That's a difficult set of test results to work with!! The best thing you can do is keep your chlorine between 3-6 at all times so that you don't end up with an algae bloom. You don't want to have to shock our pool if you can help it.
    Do not use any algaecides, unless it's Polyquat 60. The rest of them will create other problems for you, the primary one being the addition of copper to an already metal-laden pool. I would also unplug the Nature2 unit, or at least just take the cartridge out. It's not doing anything to help sanitize the water against viruses, and it also is adding copper to your pool.
    Your hardness and alk are very high. You can keep the alk and pH down by using muriatic acid, but everytime you top off the pool with water, you're adding high alk water back in, so you might find yourself fighting a losing battle there.
    Just filter, filter, filter, with your pump on low speed (2 HP is really oversized for your pool) and don't let any algae get started in the pool!
    Hi 33;
    1. Turn off the Nature2, unless no one in your family has light colored hair. When it works at all, it adds copper, and copper turns light hair green.
    2. Go to Lowes (HomeDepot, possibly a big AG supply) and get 4 gallons of PLAIN (not safe, not diluted, not non-fuming) 31.45% muriatic acid. Get some nitrile rubber gloves and safety glasses, if you don't already have some. READ the muriatic acid page in my signature, and then begin adding acid, 1/2 gallon at a time, till your pH is near 7.0. Keep it there till your alkalinity is below 100 ppm.
    3. Go to the Sams Club in Peoria, and get their PoolBrand bagged dichlor shock (24lbs). Sams is one of the VERY few retailers selling undiluted, unblended dichlor, and the price for this is excellent. Dichlor tends to lower pH and alkalinity over time, so this is a good product for you, at least for now. On your pool, 24lbs will add about 70 ppm of chlorine and about 60 ppm of CYA (stabilizer), which is about perfect. Since it's bagged, you can buy 2 boxes if you like; what you don't use will keep fairly well till next year. Alternatively, order the Kem-Tek dichlor from Amazon. But do NOT buy any other dichlor, without first becoming an expert 'label inspector' -- most of the dichlor currently sold by Costco, Kmart, Walmart, Lowes, pool stores, etc. is a MESS.
    24 lbs PoolBrand bagged shock @ Sams Club
    Kem-Tek Dichlor 22 lbs @ Amazon
    4. You'll need to switch to another form of chlorination once you've used about 1/2 of the dichlor. Look for a source of PLAIN 6% household bleach. You want a store brand that turns over quickly, so it's fresh -- bleach loses strength rapidly at summer temps. Walmart is usually ideal.
    5. If that's not available, you can use cal hypo -- but it adds both calcium and alkalinity, and is tricky to use on a cartridge filter pool.
    6. You need a spare cartridge, so you can rotate the one you have. But Hayward's website is down at the moment, so I can't look that up.
    7. Run your pump on LOW speed, 24/7, EXCEPT when you are vacuuming, or cleaning up leaf debris via your skimmer, after a storm.
    8. Meanwhile, add 3 gallons of household bleach EVERY evening, till you can begin using the dichlor.
    Jul 2012
    Illinois
    thank you for the guidance.
    July 8 evening added 2 gal bleach ad one gallon muriatic acid
    July 9 7am
    ph 7.5
    total chlorine 8-10+
    Have a cartridge ordered; will take off Nature2.
    Will continue to run pump 24/7 on low.
    will add more muriatic acid
    water is clear and sparkly. No metal deposits! Been rinsing the filter about every 2 days.
    Thanks again!
    33' round 25.6K gal AG pool; bleach; Hayward SwimPRO voyager cartridge filter; pump; 24hrs; currently: Taylor 2006c; well; summer: ; winter: ; ; PF:4.7
    Jul 2012
    Illinois
    Step from above:
    "2. Go to Lowes (HomeDepot, possibly a big AG supply) and get 4 gallons of PLAIN (not safe, not diluted, not non-fuming) 31.45% muriatic acid. Get some nitrile rubber gloves and safety glasses, if you don't already have some. READ the muriatic acid page in my signature, and then begin adding acid, 1/2 gallon at a time, till your pH is near 7.0. Keep it there till your alkalinity is below 100 ppm."
    question: I need to to have ph near 7.0 and alkalinity below 100ppm before doing anything else (except adding bleach daily and removing Nature2)? I think that may take awhile!
    Jul 2012
    Illinois
    I found some values on our well water:
    Calcium 66
    Magnesium 33
    Alkalinity 380.
    Iron 1.78
    This evening:
    ph 7.0
    alkalinity 210
    FC 0.6
    CC 0.2
    I will keep working to get alkalinity down. Then what?
    Just keep chlorine in the pool so it doesn't go green on you. What is your current CYA level?
