Results 1 to 10 of 14
Thread: Converting 15' Round Intex to Hard Plumbing
Threaded View
  1. #5
    Default Re: Converting 15' Round Intex to Hard Plumbing
    Don't try to connect hard pipe to an Intex.
    There are some vacuum adapters you can use, possibly something like this
    Intex Vacuum Tube Adaptor
    However, I am NOT recommending that, because I'm not sure it's what you'll need, or even if you will need it. Also, I hate to see a $9 shipping charge with a $9 item -- that's not a ripoff necessarily, but I'd rather find a better way.
    I'm going to be setting up a couple of Intex pools in the next week or so, and will be using them to test different products.
    This vacuum system is being marketed for Intex pools, but it has mixed reviews and sounds fairly fragile:
    Skooba Pool Vacuum Kit
    A more standard vacuum set up can be adapted to an Intex pool; if there's not something being sold, I'm sure I can work something out at Lowes:
    Poolmaster 27514 Classic Full View Triangular Vinyl Liner Vacuum
    Hydro Tools 8365 8- to 16-Foot Adjustable Fluted Premium Fluted Telescopic Pool Pole, White
    Hydro Tools 1-1/4-Inch Diameter With Swivel Cuff Pool Vacuum Hose
    Unfortunately, I can't be any more definite than that, yet.
