Thread: Algae????
    Jul 2006
    Altamont,NY
    Default Algae????
    I have a problem with my pool water, the bottom of the pool started getting some green streaks so I vaccumed the pool yesterday got the bottom of the pool clean but the water was getting cloudy the longer I vaccumed. I let the pool run all night came out this morning and the bottom has the green streaks all over the place.
    I do not know what to do.
    It is a 18X33 oval above ground pool with a sand filter.
    Chlorine is a 3 or above
    PH is 7.6
    Alkalinity is 110
    Default Re: Algae????
    You need to shock the pool and hold it at shock level until the algae is dead, and until you can go from sundown one night to just before sunup the next morning without losing more than 1 ppm of chlorine. This is going to require a test kit that can accurately and reliably check chlorine, and is also going to require that you know your CYA level, since what level of chlorine you need to achieve is determined by your CYA level. (See the "best guess chlorine chart" linked in my sig for a more detailed explanation and the chart). Vac'ing the algae out will take out the visible stuff for the day, but is not killing off or removing all the algae. You will be fighting this battle until you kill it off, which will happen with a maintained shocking of the pool.
  1. Avoiding Algae / Removing Algae
    By PoolDoc in forum Dealing with Algae & Slime
    Last Post: 07-24-2011, 10:40 PM
  2. Cloudy water...then very small amount of algae...then algae bloom
    By Allan in forum Dealing with Algae & Slime
    Last Post: 07-12-2011, 10:49 PM
  3. Wanted: Mustard algae or suspected mustard algae
    By gonefishin in forum Dealing with Algae & Slime
    Last Post: 08-30-2007, 09:40 PM
  4. Green algae? Mustard algae?
    By AE340B in forum Dealing with Algae & Slime
    Last Post: 07-15-2007, 09:32 PM
