Thread: High iron content in my city water
    Jul 2012
    Minnesota
    Default Re: High iron content in my city water
    Thanks for the great info. It makes sense the dissolved iron can't be filtered.
    I have an Intex 14' x 48" pool, Intex SWGC, and an Intex Sand filter if that makes any difference for my choices.
    I did get the 6-way test kit from Walmart and I'm still trying to lower my alkalinity. Took the plunge today after my pH minus ran out and picked up the muriatic acid from Home Depot and looked like Breaking Bad in the back yard today.
    I'll update my results when I have to fill again. I might have to try that CuLator.
    On a related note, has anyone tried or had any luck with garden hose filters, specifically the ones designed for RVs?
    Don't know about the garden hose filters, but here is the link to the CuLator.
    CuLator - 1.5 ppm unit @ Amazon
    CuLator - 4 ppm unit @ Amazon
    Quote Originally Posted by road_warrior View Post
    You have to use HEDP + the CuLator -- HEDP, to keep it dissolved, and CuLator to remove it.
    What's worked have been home-grown arrangements that filtered AND simultaneously exposed the water to air. Most likely, until your water is exposed to air, the iron is dissolved, and won't be filtered by a closed RV unit. Now, if you aerate or chlorinate BEFORE it goes through the filter, that's a different story.
  1. Which filter/pump better for water with high iron
    By tsybert in forum Intex-type Pool Setup & Operations
    Last Post: 06-21-2012, 10:00 PM
  2. Well Water very High Iron
    By meadsrm in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-05-2012, 03:58 PM
  3. What to do next? High Alkalinity & Combined Chlorine, Well Water & Iron issues
    By lady.k in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-11-2011, 02:17 PM
  4. New Pool Owner With High Iron Manually Removing Iron
    By labdi01 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-18-2010, 03:56 PM
  5. City or well for fill water
    By StevenW in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-22-2006, 09:29 PM
