Thread: 14' x 48" pool with 2650 GPH sand filter
    BigDave's Avatar
    Default Re: 14' x 48" pool with 2650 GPH sand filter
    Can you tell us the make and model of the pump / filter you're considering and that of the one you have now?
    Jul 2012
    Spring, TX
    What I have now is the 1000GPH pump that came with the Intex 14' pool. It uses the "A" filter cartridge. What I am considering is the Intex 56671 sand filter/pump.
    Jul 2012
    Spring, TX
    I thought I would update this. I installed the 2650GPH Intex sand filter/pump last week. I enlarged the openings in the side of the pool to accommodate the 1.5" fittings, and I am very happy with the increased flow from the pump. Less debris is settling to the bottom of the pool. The sand filter seems to be keeping the water very clear.
    Thanks, again, for the help... not only with this, but for the wealth of information that you have made available on your site.
    Glad it's working out for you.
    Ben
