aylad
Hi,
The first thing I would do is take it apart and see if something is hung in the impeller. If so, clear it and see if that's the problem. While it's open, see if the impeller will turn by hand. If not, find out what's stopping it. If so, and I know this sounds stupid, try putting it back together, turning it on, and when it starts humming, whacking it with a 2 x 4, rock, or other hard object to see if that will kick it into gear. There is a capacitor that sometimes goes bad, or can have corroded contacts, that will cause this to happen. If whacking it makes it come on, then we can point you to a thread with instructions for cleaning your contacts.
Welcome to the forum!
