3-week vacation
Hi all, what a great forum.
Any advice is appreciated. Learning a lot about the pool maintenance, but am now facing something I have
not done before. Will be out for 3 weeks.
1. Thought of placing leafnet cover to prevent leaves coming to the pool
(is it better to consider placing hard mesh cover that is typically used in winter
time?) If hard cover is recommended, is there any issue if pump is working?
2. will have friend come on a weekly basis to check things out - put chlorine in chlorinator, maybe
clean skimmers, pool pump filter, add water to the pool if needed etc. does my friend need to come
more frequently, just in case?
Am I missing something? Thanks a lot.
