Re: Air from skimmer line
Welcome to the forum. Seems like you have the diagnosis pretty correct. I assume you are seeing air bubbles out the returns when sucking from the skimmers and are not just referring to the air bubble that is sometimes seen under the lid of the pump basket. If your pipe connections are accessible, potential leak sites, then you could try going to recirculate mode on the filter, bypassing it if you can. This would give you a quicker response observing bubbles from the returns. Try dripping water on any suspected joints or if you don't care about appearance try silicone seal or vaseline if you can wipe it off easily. If you hit the leak, the bubbles will stop quickly. Depending on the noise level the open end of a stethescope hose can pick up air leaks pretty well. Doesn't take much of a leak to cause your problem. See if any of these suggestions help and let us know how you're progressing.
