Thread: Pool equipment
    White Plains, NY
    Default Pool equipment
    I just cancelled my pool service. I received my PS234 so I'm set for testing. A couple of questions; what is the best vacuum recommended? Also, I see there is a hayward chlorinator attached to the intake before the pump. Should I just ignore it or should I remove it?
    Default Re: Pool equipment
    You can ignore it--if you're not going to use pucks in it, just open it up all the way, and pretend it's not there
  1. Pool Equipment
    By cforge in forum In-Ground Pool Construction and Repair
    Last Post: 06-21-2012, 10:14 PM
  2. Researching pool equipment
    By GatorWayne in forum In-Ground Pool Construction and Repair
    Last Post: 04-02-2012, 12:29 AM
  3. pad for pool equipment
    By johninmartinez in forum Pool Equipment & Operations
    Last Post: 08-09-2011, 04:58 PM
  4. Help...freezing pool equipment!!!
    By poolboy69 in forum Pool Equipment & Operations
    Last Post: 02-05-2011, 06:16 PM
  5. Need the same equipment the pool guy has?
    By bkny1055 in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-02-2009, 01:36 PM
