Thread: Sams/Costco Chemicals
    Jul 2012
    Dallas, TX
    Default Sams/Costco Chemicals
    Are these chemicals ok to use? I've heard that they have inert/bad ingredients in them that can turn pool water green or cause other issues.
    Default Re: Sams/Costco Chemicals
    For the most part, the chems from Sams are okay to use--in fact, their dichlor (PoolBrand) is the one that Ben recommends. Costco, on the other hand, has been known to sell some of the chems with added "goop" that we try to encourage people not to use. If you're buying trichlor tabs, check the ingredient label and don't buy any that have copper listed as an ingredient--and don't waste the extra money with the zinc blends they've come out with this year. They don't seem to have any real effect on the water, but they cost twice what normal tabs do.
    Welcome to the forum!!
    Honesdale PA
    If I remember right, a few years ago, I saw two flavors of pucks at Sams. One was a Multi action or something like that and the other just plain. Ingredients however both showed the same so you couldn't tell from that part of the label. Maybe the multi one had copper? I think the multi was a little more expensive too. Always get plain. That was at a Sams in northease PA.
    Could be. "Multi-action" is a bad word, when it comes to pool chlorine, and usually means 'goop'.
    In my area, and online, the only products I've seen this year the unblended PoolBrand stuff, but that doesn't mean they can't slip some bad stuff in at local stores.
  1. leisure vac from costco
    By fog80 in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-03-2008, 11:41 PM
  2. Is the COSTCO Aquabot Turbo C Exclusive to COSTCO ?
    By akrauss in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-09-2007, 10:32 PM
  3. Costco Calcium Hypochlorite
    By MarkC in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-04-2006, 11:05 AM
  4. Sams Club Pools?
    By badkins in forum Above-Ground Pool Construction & Repair
    Last Post: 05-02-2006, 05:10 PM
