Having trouble with the plastic drive gear on Baracuda MX8 wearing out
I've had this cleaner for 8 months and so far I've replaced both directional engines and both drive shafts just because the two plastic gears between the drive shaft and directional engine are wearing out. I wouldn't mind replacing just these two gears every 6 months or so but I'm unable to locate the gears themselves and replacing the major assemblies is cost prohibitive.
Thanks in advance,
POOLLEDS
