Thread: Longtime creeper, first time poster
    Default Re: Longtime creeper, first time poster
    Here's the form you're looking for..
    Pool Chart Entry Form
    Pool Chart Results
    If you'll just fill it out, and post your test results (particularly CYA), as well as what chems you've used in the pool this year (ingredients, please--not product names) we'll be glad to help you go from there!
    Calculated your pool volume (3' 10" actual water depth) as 16,000 gallons, for a PF of 7. Each gallon of PLAIN 6% store brand bleach will add 3.5 ppm of chlorine.
    So . . . add 5 gallons of bleach tonight! If you can remove all chemicals and mineral cartridges, pour the bleach through your skimmer, to kill algae trapped there. Plan to add 5 gallons tomorrow night, too.
    Meanwhile, post your readings, here!
    Jul 2012
    Central Texas
    OK! I bought 4 giant jugs of bleach on my way home. They are going in tonight! Stay tuned.
    Jul 2012
    Central Texas
    OK:
    CL <0.5 big surprise there, huh
    pH >8.2 but, it was a really pretty shade of fuschia =)
    CYA >40 the black dot never went away? Did I not do it correctly?
    Hardness test was 230 ppm
    Did you run the pH test before or after adding the bleach? High chlorine levels can give falsely high pH readings. But, if your pH results are before the big dose of bleach, you need to lower it to between 7.2-7.8. You can use muriatic acid to do so but please read the link in my signature about using the acid safely.
    If the black dot never went away on the CYA test, it means that your CYA is less than 30 and you need to raise it up to around 40-50.
    Jul 2012
    Central Texas
    Watermom,
    I haven't added anything to the water yet. The readings were taken on the water as it was when I got home from work today. We'll add the bleach in a little bit when it gets cooler (as if!) outside. I'll check the levels again in the morning before the sun gets too happy.
    27' round AG/Sand filter/1.5 hp Hayward Power-flo
    God Bless Texas and Sic' em Bears!
    27' round 17.5K gal AG pool; skimmer tabs; Ranger sand filter; Hayward Power-Flo 1.5 pump; 12-15 (on recirc usually)hrs; HTH 6-WAY; utility water; summer: ; winter: ; ; PF:6.9
