Thread: Fittings are yellowing...returns and drains
    Default Fittings are yellowing...returns and drains
    Hi All,
    I am a practicer of the BBB...My vinyl lined pool has never been cloudy and maintenance has been a snap for 7 years.. It is a heated pool. I have found my PVC fittings going yellower each year, however my steps and ladded steps are AOK. What is causing the discoloration and can i reverse it?
    Thanks...
    Largo, Florida
    Default Re: Fittings are yellowing...returns and drains
    Mine do the same thing. I was assuming it was staining from some minerals in the water, and was actually planning on replacing them next year since they're fairly inexpensive.
    mbar's Avatar
    Ashland, PA
    I just think the get yellow with the choline, and age. You can try rubbing some vitamin c tablets on them to see if they turn white. It would not be worth doing an ascorbic acid stain treatment if that is the only yellow you have. Just crush up some vitamin c and put it in a sock and rub.
    Northeast PA
  1. 2 Items Yellowing At Water Line in Steps Area and Sand discharging into Pool
    By terradon973 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-11-2011, 08:50 AM
  2. Copper fittings and chlorine
    By LukeNorris in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-27-2007, 12:06 AM
  3. Yellowish fittings-CL overdose???
    By otitis in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-14-2006, 11:15 PM
  4. Wall fittings
    By duraleigh in forum In-Ground Pool Construction and Repair
    Last Post: 05-11-2006, 12:38 PM
  5. Return Fittings Missing . . .
    By SJohnson in forum In-Ground Pool Construction and Repair
    Last Post: 04-12-2006, 09:01 PM
