Results 1 to 10 of 29
Thread: high pH and TA, cloudy water
    Default Re: high pH and TA, cloudy water
    As your pH comes down, so will your alk--and as the pool is aerated by swimming, splashing, etc, the TA will slowly be stripped away (until it raises again when you top off your pool )
    There's not much of a way for me to guess how many additions it will take to bring the pH down--a lot depends on how high the pH really is, what your TA is (the higher the TA, the more likely it is to take more MA) and what your actual doses really are. You'll just have to add, test, and adjust--trying to shoot for exact numbers doesn't work very well!
    Jul 2011
    New York
    Tested late afternoon.
    CL 1-3
    pH 7.8
    TA 190
    Added MA.
    Tested now (about 2-3 hrs later)
    CL 1
    pH 7.5-7.8
    TA 240!
    Why did the TA increase with the MA??
    Ugh. This is so frustrating. I see no difference in the water's clarity...still very cloudy. Now perhaps slightly green tinged.
    I added the rest of the pH down (just to use it up -about 9 oz). Waited a few mins and added a gallon of bleach. Will test again in the am.
    Acid isn't the only thing that will cure cloudy water--and with a CYA of 50, a Cl of 1-3 isn't nearly enough to keep algae from growing in the pool. I would shock the pool to 15-18 ppm, using bleach, and hold it there until you can go from sundown to sunup without losing more than 1 ppm of chlorine. I'm betting your cloudy water is an algae bloom, not a pH issue.....
    Jul 2011
    New York
    Thanks Janet. That's what I am now wondering, since my cloudiness has turned greenish. I added a gallon last night, and my walmart kit is reading "at least" 5 (it's slightly darker yellow than that). How do I know if I am at 15-18? Add 2 more gallons and "hope?" This am my TA is down to 180 and the pH is 7.5 Should I add some more MA too?
    I wouldn't worry about the TA and pH right now. pH is fine where it is, and TA isn't going to be critical right now, as much as clearing up the algae is. Here's how to force your kit to read higher chlorine readings than it was designed to....
    http://www.poolsolutions.com/gd/how-...d-testkit.html
    If your pool is 24' diameter, and 48" from floor to water level, then I'm estimating about 13,500 gallons. Do I have the dimensions right? In 13,500 gallons, each 1 gallon of 6% bleach you add is going to raise your FC by 4.4 ppm. Each 3.5 cups of bleach will raise your FC by 1 ppm, so you can use those as a reference point. You need to get it up to 15-18 ppm and hold it there by testing as often as possible and adding whatever amount of bleach you need to get back up over the 15 ppm mark, until you can measure at sundown and then again in the morning before the sun hits the pool, and not lose more than 1 ppm of chlorine in that time. When you get to that point, and the pool has cleared up, then you can let your chlorine drift back down--but only to the 3-6 ppm range. Any lower than that, and you're going to have algae growing. If you can, brush the pool after your chlorine additions, and keep your filter running 24/7 during the process, cleaning the filter as your pressure indicates.
    She listed 24 round x 3.5' depth on the pool chart. Assuming that the 3.5' is overflow, and her WATER depth is 3', her volume is ~10,000 gallons as she estimated. If the WATER depth is 3.5' (48" walls) then her volume may be closer to 11,800.
    Jul 2011
    New York
    Thanks guys. Off to add more chlorine. Hubby says its closer to 4ft. He was estimating about 14,000 gallons, not the 10K I thought. I ordered more CYA reagent from the Amazon link last night, so hopefully that will come soon. can I get distilled water at Walmart? Will need to run there and get more bleach bc I think I only have 1-2 more gallons at home.
    J
