Make sure you provide the proper spacing around the heater for servicing (removing heater grid, etc) and to allow radiant heat to escape. If the noise is mainly from the exhaust (like mine) you may be able to just add an extension exhaust stack (I assume you have a gas heater and not a heat pump) to divert some of the noise. I think a block wall alone will add enough sound insulation you souldn't need anything else. There is a high temp insulating material used to cover the inside of van/motor home engine covers that can be purchased cheaply by the roll at places like JC Whitney catelog if you want to go to the extra trouble. It looks like a foil covered roll of fiberglass insulation.Originally Posted by Lenny
Good luck
