Results 11 to 17 of 17
Thread: Black / Brown algae
    David Kol Guest
    Default Re: Black / Brown algae
    Here are 2 pictures of the problem. These patches are more towards the outer edge of the pool. 24 ft pool, and the problem is fairly well confined to the outer 6 or 7 feet. Approx 6 to 7 feet from the center out has no noticeable problem (yet) As the cl level is increased, the darkness of the patches starts to go away.
    I am now working on getting the cl to the range of 15ppm (as suggested here). Should I work on lowering the PH from the 7.9 now, or what until I get the CL level up.
    David
    gregugadawg Guest
    black algae isn't going to grow in a vinyl lined pool, it needs a rough surface to attach on to as in a plaster surface. Also black algae is going to be no larger than a quarter in diameter. It is possible to be brown/mustard however that easily brushes up but is persistent. Try to rub a vitamin c tablet on the discoloration and see if it comes up, if so then it is a stain.
    David Kol Guest
    Rubbing, scrubing, brushing had no effect on patches last year. This year we have rubbed with the brush on the vacuum head, and you see ZERO improvement.
    The readings this morning after adding bleach yesterday based on the calculator, and acid for the ph late last night, are
    cl 14PPM
    ph 7.4 -7.5
    cya 30-35 (subjective to when the black ball is not visable)
    david
    David,
    Now, I believe, you have to keep up and maintain the regiment of high CL, daily brushing and vacuuming--that almost looks like a mold there, but high chlorine levels should kill it. I doubt ascorbic acid will do any good to those patches.
    I believe it will just take time, persistance, and lots of bleach.
    gregugadawg Guest
    have you tried to rub a vitamin c tablet on those STAINS yet. that is not algae especially after i saw the pics. Black algae won't grow in a vinyl pool
  6. #16
    David Kol Guest
    We will try the vitamin c tablet today. We need to pick some up.
    cl level this morning 14ppm
    David
  7. #17
    David Kol Guest
    We tried the vitamin c rub, and saw no improvement. We rubbed the same spot 3 times.
    Is it possible that this is a stain that starts to disapear or get masked at the cl level rises????
    If i go to the bottom of the pool and scrub with a fairly stiff brush, I see no particles that are coming loose.
    Water tempyesterday got to 84*. Added 1.5 gallon of 5.25% bleach last night to maintain approx. 15ppm cl. ph is 7.4 / 7.5 and cya is 30.
    we are running the filter 24/7, and vacuuming daily.
    below is a picture of the problem
    David
  1. trying to get rid of black algae
    By tulsapool in forum Dealing with Algae & Slime
    Last Post: 06-25-2013, 01:45 PM
  2. Black Algae
    By hannaswims2013 in forum Dealing with Algae & Slime
    Last Post: 05-29-2013, 02:45 PM
  3. Help! possible black algae
    By sugargirlz44 in forum Dealing with Algae & Slime
    Last Post: 07-17-2006, 05:20 PM
  4. Black Algae - what does it really look like?
    By jhm in forum Dealing with Algae & Slime
    Last Post: 07-05-2006, 01:34 PM
