Re: Water Question
I don't know the answer to the reverse osmosis question, except that the water probably does have chlorine in it until it gets to the pool--and then is used up by either stuff in the pool, or the Texas sun. Do you have stabilizer (CYA) in your pool?
It is fine to use the bleach in a pool with a vinyl liner--I've been doing it for years, as have many folks on this forum! What levels of chlorine you need to maintain will depend on your CYA level (see the "best guess chlorine chart" linked in my sig for more info there), and if you'll tell us about your pool here
Pool Chart Entry Form
we can help you figure doses.
