Re: It's too easy being green
You have to keep adding chlorine - but you must be consistant. Don't let it drop down at all. Keep it at 12ppms, and keep the filter running 24/7. If you have a sand filter, you can put a cup of DE in the skimmer. You can also cut the leg off a pantyhose stocking and put it in the skimmer basket - it helps to filter out small particles. I opened my pool to a green swamp on Thursday. Using lots of bleach, keeping my filter running 24/7, and vacuuming everyday with a sock on the skimmer basket, a cup of DE in my sand filter, I now have clear water. It did take 3 full days to get completely clear. Have patience, and keep up with the chlorine. It will clear up.
Northeast PA
