Results 1 to 10 of 17
Thread: Hello
    Jul 2012
    Dallas
    Default Hello
    Hey all - new to pools from Texas.
    Purchased a cheap 10' pool from wally-world to determine how much we like taking care of one and if we were into pools for the long haul. Perhaps in the near future we will add a permanent pool to our backyard.
    Currently learning about pools, what does and doesn't work, and how great they are in these Texas summers!
    We recently went out of town from Fri-Sun and forgot to add chlorine before we left (oops). Unsurprisingly came home to a greenish pool. Since it is only around 1100 gallons I decided to drain and refill instead of battle the nasty for a week.
    Last night I refilled and added around 1/2 gallon of bleach (the bleach I had was from the dollar store and I can't find the actual percentage, plus it is several months old so it likely is even less than when fresh).
    Today I removed the rest of the leaves and vacuumed/scrubbed the bottom of the pool. (Did I forget to mention our pool gets very little full sunlight because of our massive pecan tree? This is one of the reasons putting in a permanent pool is so hard for us, we'll have to lose our tree). I am planning on trimming some tomorrow, but it will probably only add about 1-2 full hours of sun per day.
    Tonight I am sitting with a clean pool, that just may be slightly cloudy. After testing everything this evening with my K-2006 ordered through the links here on Amazon:
    FC: 5.0
    CC: 1.0
    pH: 8.0+ (stupidly added a lot of borax when I added a lot of chlorine...)
    TA: 100
    CYA: 0
    I have since tossed 2 - 1" tabs of dichlor, and probably stupidly 1/3 cup of HTH stabilizer.
    Ran out of bleach over the last couple of weeks so I am about to go buy about 3 gallons. Planning on adding about 1/3 of a gallon to bring it up to shock level then testing it in the morning and holding it there for a couple of days since I have a CC reading.
    Looking forward to reading and learning more here, figured it was time to register and be a part of your great community.
    Default Re: Hello
    Hi,
    It certainly looks like you've done your homework, and that's going to make pool care so much easier for you...
    How sure are you of your volume? How deep is your pool from floor to water level?
    Your plan to increase the chlorine levels for the next couple of days is right on the money. Having the dichlor (and the stabilizer) in the pool is not a bad idea, either--just make sure that the bleach doesn't come into direct contact with the tabs before it's mixed in the water (are you sure that's dichlor and not trichlor?).
    Welcome to the forum!
    Jul 2012
    Dallas
    Default
    Hi Janet,
    Not real sure of the volume, I confess I've just relied on what the box said--and it even said approximate. I will do some calculations tomorrow and come up with a better number.
    You're actually correct, the tablets are trichlor 1" tablets. I am also using a 5lb. jug of Kemtek dichlor that I purchased through the link to Amazon from here. Unfortunately, early last week I grew complacent and didn't check chemicals for several days, culminating in the weekend getaway. I knew full well I had no CYAs before I left (I had not used much of the trichlor or dichlor). Live and learn, some things even y'alls warnings can't prevent...
    Instead of running to the store this evening I just used more dichlor to bring the FC up to 18.5 (just tested) which I will presume is about right even though I haven't tested for CYA since adding my stabilizer a few hours ago.
    I intend to test a full suite in the morning to find out how the CYA I added actually took and where my FC stands after the evening. I have terrible squirrels in the trees that use the pool as a basketball hoop so the cover stays on unless we're in the pool.
    FWIW, the trichlor is probably a no-no, but I purchased it in a pinch while waiting on my Kemtek dichlor to arrive.
    Oh, one more thing...my little micro-pool is setup to add the tabs in the type-D filter, and I add chemicals in the other end of the pool.
    Default Re: Hello
    Make sure your trichlor tabs do NOT have copper in them! If they are 99% trichlor, that's the good stuff and fine to use for awhile to help build up CYA. However, if you are using trichlor and dichlor, both of which add CYA, be careful not to get too much CYA in there. A level of 40-50ppm is what we usually recommend for most pools.
    Jul 2012
    Dallas
    Default Re: Hello
    I knew the trichlor was a no-no, it does have about 5% copper such and such. I really only got it in order to add CYA while I was waiting on the dichlor to arrive so I don't really use it.
    After the additions of dichlor and stuff last night I finally got my first CYA reading this morning.
    This morning I am at:
    FC: 16.0 (down from 18.5)
    pH: 7.5
    CYA: 60 (oops--in my desire to finally show some it looks like I overshot the target a little)
    From the 'best-guess' chart I guess I will hold my chlorine at 20 for another day or two until I quit losing more than 1ppm. My only fear is that since I now have CYA at a decent level and I don't get much sunlight that I won't be able to get my chlorine down within about a week...
    Default Re: Hello
    That won't be a problem, if you can leave it uncovered. I am near Shreveport, and have to keep my stabilizer around 90- 100 ppm to slow my chlorine loss to a reasonable amount. If you can leave it uncovered for a day or so, it'll come down.
    Default Re: Hello
    I'm impressed. You've jumped right in and pretty much worked it all out!
    By the way, post 1 or 2 more times, and you'll automatically move to the no-longer-moderated category. I can do it manually, but it screws up some things, so I'd rather not.
    Welcome!
    Jul 2012
    Dallas
    Default Re: Hello
    Thanks.
    For some reason it wasn't letting me reply in this thread but I figured it was a 5 post limit.
    I wasn't home all day Tuesday so I wasn't able to test or anything.
    After about 36 hours with no interaction my FC was at 17.5, down by about 4ppm. CC was less than 0.5, I didn't really want to use up all my chemicals by using the 0.2 steps.
    Today, after about 18 hours I was down 1ppm FC from the 17.5 and still less than 0.5ppm CC so I decided to pull the cover and let it come down to normal. I swapped the filter to a brand new one to get a fresh start.
    I may still have a slight thing going on but I wanted to float a little this weekend so I'll just watch it really closely and make sure the FC stays around 5 at the minimum.
    I will probably shock it back to 20 or so next week when I know nobody will be in the pool.
    Thanks for the plethora of good information all across this board. I read a lot before actually joining, but at some point I had to stop and start trying some of it out.
    Hopefully one day I can talk the wife into a permanent pool.
    Default Re: Hello
    Dunno about your budget, but Walmart and other big box stores have Intex pools on clearance currently. You might want to look at something a little bigger. A 10' is actually harder than a larger one, because the dilution factor (diluting people goo) is NOT in your favor.
    But, I can say a LOT of people here have started with, and enjoyed an Intex pool for several years before moving up.
    Good luck!
    Jul 2012
    Dallas
    Default Re: Hello
    Thanks, I'll have to look into that. I suspected a smaller pool would be more difficult to keep stable but already talked the wife up to the 10'. Now that we have had it for several weeks I could probably talk her into a larger one.
    For some reason my nearest Walmart doesn't have a selection of more than the most basic of pool gear even though it's a brand new super center.
    I'll start checking the other stores and sam's club.
