Results 11 to 17 of 17
Thread: Hello
    Default Re: Hello
    Walmart's clear out pool gear ASAP after July 4th.
    Check Kmart, Target, other big box stores for clearance deals on Intex pools. But you may have to purchase bits and pieces from Amazon.
    Jul 2012
    Dallas
    Default Re: Hello
    Quick question or two or three, (should I start a new thread somewhere?)
    I'm pretty stable now and have come down to chlorine levels more appropriate for swimming/floating.
    (1) What do I do when I go out of town? I have the filters that allow for me to stick a 1" tab in there to disperse, but the only tabs that I have are trichlor+copper-such-and-such...Should I just "shock" the pool up to around 20Cl and then cover it?
    (2) When I test for CCs, which isn't every time I test the water since I've become fairly stable IMO, I get a very slight pink hue which always takes 1 drop of reagent to clear up. I have been calling this CC <0.5 but is that in any way accurate? To be more clear, it is not dark pink, but very VERY light pink.
    (3) If the above really does indicate I have a small amount of CCs then should I shock to 20 and wait until there is absolutely no presence of CC? I feel like there will always be a very tiny bit of CCs in a pool.
    (4) Thanks for the heads-up on the Intex deals, but my wife shot the idea down. Possibly next summer for a bigger pool. Is there a "best" size for Intex? I guess by that I mean is there a pool that provides the best mix of included pump/filter/volume. I think the most yard we're willing to sacrifice would be for a 16' pool at the most.
    I've attached two screenshots of my excel spreadsheet so far: Screen Shot 2012-07-24 at 1.53.09 PM.pngScreen Shot 2012-07-24 at 1.52.59 PM.png
    Default Re: Hello
    1. I'd recommend a floater . . . EXCEPT that fumes from it may kill the cover, at that point. 20 ppm + cover should be OK. Just take it up to 20ppm a day BEFORE you cover (top it off if necessary) and then try to stay out of the pool for 24 hours. Gases can form from that 20 ppm + people goo. Uncovered these gases escape and cause no problem; covered they could attack your cover.
    2. Do NOT worry about a minimum CC reading (0.5 if using 10ml; 0.2 if using 25 mil). I'm not quite sure what that is, but I've quite sure it's not a real problem.
    Jul 2012
    Dallas
    Default Re: Hello
    Great, thanks. That was what I figured about the CC reading.
    And FWIW, the cover does have the holes to prevent rain water from accumulating. But I will do as you suggest.
    I am going to try and avoid the floater for now, I only foresee a couple of short 2-3 day trips in my future.
    Default Re: Hello
    2 or 3 day trips are no problem. It's the week or longer trips that take some planning.
  6. #16
    May 2012
    Oklahoma
    Default Re: Hello
    Just up the road from you and I can tell you that for the most part, as long as you have the chemistry good enough, I have found with the cover on, I can leave the pool alone for a week and feel confident that nothing will grow. That said, if someone uses it during the week, before it get's closed up for the night it ALWAYS gets it's levels tested. If you haven't got that good Taylor kit from PoolDoc's links yet, do. I know you have a small pool (like me), but it ensures absolute clarity on chemistry levels......which is the key to keeping that little pool good for the kids.
    My two cents worth on pool size. I am very much in the same place as you. Every year for the past three years, I have grown in pool size. We are looking at the 15' metal frame pool or the 16' metal sided pool. We simply don't want to take any more of the back yard up with a pool and/or don't want to spend thousands of dollars on an inground either. Nice to have the option of......well, kids done with the pool, let's wrap it up and throw it out. Alot better than around 1/2 my neighbors who have filled in their pools after the kids leave.
    OK, one more comment. For me, the pool cover has made all the difference THIS year over past years when I did not cover my pool(s). Chemistry does not change fast (or I can keep ahead of it now) and much less filter changing.
    Hope your kiddies enjoy the pool like ours do!!
    Bob E.
    Intex 10' x 30" metal frame pool, Intex 2500 gph filter/pump, Intex Saltwater generator, SwimMax 11KW heater, 2 x Small Game Solar Domes.
  7. #17
    Default Re: Hello
    As one who started with an Intex donut and moved to a full-sized pool it was for me an excellent training experience. When I got my FantaSea I was already pretty good at keeping my Intex pristine. That was a 15' round. Since now the 15' donuts are SO cheap (even Toy'r'Us sells them) I don't see why you don't upgrade.
    BTW, when your pH was 8 and your CYA=0, that's a GREAT time to use Tri-chlor tabs, albeit without copper, as they add CYA and lower pH, while maintaining fairly consistent FC levels.
    The hardest part about small pools is getting the right amounts of stuff in without over-doing it. If your pool is about 1000 gallons, then you can use the Rule of Thumb calculation of chlorine--and increase or divide by 10 as needed:
    1 Gallon of 6% Bleach adds 6ppm of FC to 10,000 gallons.
    5.25% adds 5.25 ppm, 12% adds 12ppm.
    Now with your 1,000 gallon pool, you use 1/10 of a gallon to get the same effect.
    Or...1 quart of 6% would add about 15ppm (roughly) to your 1000 gallons. (15= 1/4 of 6*10 )
