If your pool is filled, you need to make sure it has between 1-3 ppm of chlorine in it at all times to keep it from going green. I'm assuming there's no stabilizer to protect the chlorine from the sun, so you'll need to add chlorine a few times during the day to make sure it never goes below 1 ppm. You can use plain, unscented bleach for this, but I need the volume of your pool before I can give you a dose.
You also need to run a set of tests on your water with a drop-based kit. If you don't already have one, we highly recommend the K-2006, which can be found in the link in my sig, but in the meantime, go to WalMart and see if they have the 6-way hth drop kit, which will suffice until you get a better one. At the absolute minimum, at least pick up a cheapie OTO kit (uses red and yellow drops for pH and chlorine) and measure your chlorine and pH with that.
In hot weather, it only takes a few hours for algae to start growing in a pool without chlorine!
