Fluctuating Levels
I am totally perplexed. Since our bout with mustard algae at the beginning of the season I have used the BBB method for our pool. I have been VERY diligent to keep the levels where they should be. Here is my problem. My CYA levels are never the same. (When I get strange levels, I test again to make sure I did it right the first time) Granted, in the past 1 1/2 wks we have had to drain some of the water d/t the tremendous amount of rain we have gotten so I expected it to drop some. Have not used the floating chlorinator with 3 in. tabs in about 1 1/2 weeks. Here are the levels :
7/12- FC-8.0 CC-0 PH-7.4 ALK 70 CYA 70 7/13- FC-5.0 CC-0 PH 7.4 ALK 70 CYA-40 7/15- FC-2.5 CC-0 PH-7.3 CYA-60 added 1 1/2 gal. 6% bleach 7/16-FC-4.0 CC-0 PH-7.2 ALK-60 CYA-35 7/17- FC2.0 CC-0 added 1 gal. bleach 7/18- FC-4.0 cc-0 PH-7.4 ALK-70 CYA-50 added 2qts bleach 7/19- FC-3.5 CC-0.5 PH-7.4 ALK-60 CYA-30
Why is the CYA fluctuating? Pool is crystal clear. Water temps have been 90-94 degrees for the past 2 weeks. Test the water around the same time each evening, 6:30 to 7pm, after the sun is off of the pool. Am I obsessing over the levels? Just don't want to have algae again. Thanks in advance for your input. You guys and gals are the best!
1 1/2hp Emerson 2speed pump, BBB
27' round 19.3K gal AG Vinyl Liner pool; sand filter; pump: 24 hrs on low; Taylor K-2006 FAS-DPD Chlorine; utility water ; PF:6.9
