Thread: Intex pool question
    Jul 2012
    North Carolina
    Default Intex pool question
    Can we use only bleach and borax with this intex pool? I read through the sticky for intex pools which said you can use bleach for the first 7 days until your chemicals arrive. Just wondering if we can stay with using bleach for the rest of the summer.
    Thanks!
    Default Re: Intex pool question
    You can continue to use bleach for your chlorine in this pool--you'll just have to add your stabilizer (CYA) seperately. You can get that at any pool store, but WalMart (at least the ones down here) sell it in the spa section. It's often labeled conditioner, or balancer, but if you look at the ingredient label, and it says cyanuric or isocyanuric acid, then that's the right stuff.
    Welcome to the forum and to the world of pool ownership!
    membership upgraded.
    you might want to look at this sticky post, on basic Intex pool chemistry: http://www.poolforum.com/pf2/showthread.php?17055
    -ben
  1. Intex 18ft 48 deep pool question on chemicals
    By Sin2001 in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-19-2012, 10:10 PM
  2. Intex Salt system and Sand Filter Question
    By 2manycars4me in forum Intex-type Pool Setup & Operations
    Last Post: 07-18-2012, 01:03 AM
  3. Salt Water Generator / Intex Pool Question/advice
    By Indywar in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-05-2012, 02:16 PM
  4. Intex Pool 18 x 48 a general question
    By reboot530 in forum Intex-type Pool Setup & Operations
    Last Post: 06-27-2012, 05:56 PM
  5. New user, question about sand filter for use with Intex pools.
    By DanielH in forum Above-Ground Pool Construction & Repair
    Last Post: 06-22-2011, 09:29 AM
