Thread: Aqua Comfort S125 Heat Pump Not reading Water Temp Correctly
    May 2012
    NJ, USA
    Default Aqua Comfort S125 Heat Pump Not reading Water Temp Correctly
    Hi. For the last 3 days it has been very hot outside and my Aqua Comfort S125 heat pump is reading 104 to 105 degrees while the actual water temperature is around 88 degrees. The top temp on the heater is 95 so I can not turn it on to see if I can move the water through the pipes. I was wondering if anyone had any ideas on what could be causing this besides a bad thermostat. I had that changed 2 years ago and it was working fine until 3 days ago. No error codes are being displayed.Thanks.
    Default Re: Aqua Comfort S125 Heat Pump Not reading Water Temp Correctly
    Hi ghostcat, love your username!!
    That is a question very specific to the unit you own. I don't know if anyone can answer that for you or not, but hopefully somebody can help. In the meantime, you can use the google search linked in my sig to search through the forum and archives to see if you can find any helpful information that way.
    Welcome to the forum!!
    May 2012
    NJ, USA
    Thanks. I hope someone has an idea.
    I can't help with your question either, but wanted to say thank for the subscription!
