Thread: SWG and warm water..
    Scottsdale, Arizona
    Default SWG and warm water..
    Living in Arizona, my water gets quiet warm mid summer.. Will this limit my SWG from prodcuing enough chlorine?
    Anyone have experince with issues due to the warm water temps?
    EricF is offline ** No working email address ** EricF 0
    Greenville, NC
    Default Re: SWG and warm water..
    Autopilot claims their unit works up to 104 degrees. I have an aquarite system that worked well last year despite water temps in the low 90s (Ugh). I will be trying a fountain at night to cool the water this summer.
    EricF
    Saint Cloud, FL
    There should be no problem, provided you keep the CYA at 50 - 60 ppm.
    When you try the fountain, keep an eye on your TA in case it starts to drop, if the pH is at 7.2 - 7.4.
    Hope this helps.
    Pat
    Richmond Hill Ontario Canada
    Chlorine production is a function of water temperature and salt level. Higher salt = more chlorine production. Higher temperature = more chlorine production.
    Mark Manning
    Watermaid Canada
    www.watermaid.ca
    [email protected]
  1. Draining Pool for Warm Climates?
    By mida68 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-19-2007, 01:55 PM
  2. Does algae grow better in warm water or in cooler water?
    By keithw in forum Dealing with Algae & Slime
    Last Post: 10-02-2006, 12:39 PM
  3. Warm pool at night with steam/vapor?!?!
    By endeavor in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-09-2006, 03:34 PM
  4. Warm up, darn it
    By huenix in forum General Interest
    Last Post: 04-25-2006, 06:33 PM
