Thread: Alkalinity stuck at 0...after 50 lbs. Alkalinity Increaser
    Jul 2012
    Ohio
    Default Alkalinity stuck at 0...after 50 lbs. Alkalinity Increaser
    The alkalinity is stuck at 0. After putting in 25 lbs. of Alkalinity increaser it did not raise. Another 25 lbs. of Alkalinity increaser and still it's registering at 0. What could be causing the Alkalinity to lock up like this? This is only a 9000 gallon pool!
    Default Re: Alkalinity stuck at 0...after 50 lbs. Alkalinity Increaser
    I'm afraid Watermom is right; something is SERIOUSLY wrong either with what you are adding, or with the way you are testing.
    Check the packages: if they say "sodium bicarbonate" or "sodium acid carbonate" or "sodium hydrogen carbonate" as the ingredient AND the material inside was a fine gritty white fast dissolving material . . . you added the right stuff.
    If so, toss your kit!
    + Here are links to the kits we recommend:
    HTH 6-Way Test Kit @ Walmart
    Taylor K2006A (3/4 oz bottles) @ Amazon
    Taylor K2006C (2 oz bottles) @ Amazon
    moved thread where it goes -- you can post again now. Sorry! Ben
  1. Is baking soda an acceptable substitute for Alkalinity Increaser?
    By Gary carpenter in forum Dealing with Alkalinity and Calcium
    Last Post: 07-01-2013, 08:02 PM
  2. Ph 6.6 Alkalinity 50 HELP
    By timmie in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-27-2009, 12:37 AM
  3. Alkalinity
    By newbie2pools in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-26-2006, 07:31 AM
  4. Total Alkalinity and Adjusted Total Alkalinity
    By cheshamjim in forum Dealing with Alkalinity and Calcium
    Last Post: 06-18-2006, 09:36 PM
  5. Alkalinity FAQ
    By VickieC24 in forum Dealing with Alkalinity and Calcium
    Last Post: 04-04-2006, 11:03 PM
