Thread: My first test... questions
    Jul 2012
    Chicago
    Default My first test... questions
    I got my K2006 test kit in the mail today and had a couple of questions. I watched the videos on Youtube before using the kit. When I tested CYA the comparator tube was full when the black dot disappeared. There is no label at the top of the tube, but I estimated it to be about 25, does that sound right?
    Also, when testing pH I had a really hard time comparing the colors when I held the comparator tube up to the sky, like they do in the video. The water looked almost clear compared to the colors you're comparing to. I'm guessing the blue sky messed with things. When I looked into a white towel I had more luck and it looked like about 7.3. Am I messing up the test by looking at it into a white towel?
    After getting answers to these questions I'll post my full results and ask for recommendations.
    Thanks!
    18x36 rectangle 20.6K* gal IG painted concrete pool; floater; Pentair Tagelus sand filter; Pentair SuperFlo 1.65HP pump; 12 hrs; gas heater; K2006 Taylor; utility water; summer: none; winter: Haven't gotten to my first winter yet; none; PF:5.8
    Default Re: My first test... questions
    25-30ppm on the CYA sounds about right and using a white towel as a background to check pH is just fine.
    Jul 2012
    Chicago
    Well here is what I got:
    CYA: 25
    PH: 7.3
    FC: 0.8
    CC: 0.6
    TA: 110
    CH: 180
    I know I need to get my chlorine up so I added a bottle of 6% bleach tonight (1.42 gallons). I'll retest in the morning and post results. Anything else I should do based on those numbers? Should I add stabilizer? 25 is kinda low isn't it?
    Yes, stabilizer of 25 is kinda low. I think you'll do better at 40-50ppm. Go ahead and add another 5lbs of CYA.
  1. Test results and questions
    By Jeffski in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-09-2009, 01:14 PM
  2. CH Test Questions/ CH Rising
    By Gracy101 in forum Dealing with Alkalinity and Calcium
    Last Post: 04-11-2007, 04:13 AM
  3. Newbie first test results. Some questions?
    By mjs31 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-02-2006, 05:37 PM
  4. test results and SWG questions
    By poolbee in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-18-2006, 01:27 PM
  5. Test Results questions
    By DaveInPA in forum DPD-FAS based testing
    Last Post: 05-30-2006, 11:50 PM
