Thread: Flexible hose instead of PVC?
    Default Flexible hose instead of PVC?
    I'm looking to swap out a sand filter and have to rework the plumbing some. Part of my existing plumbing has a white flexible hose that I will probably have to replace. What is that called, where do you get it and does it take some special adhesive for proper joining?
    Default Re: Flexible hose instead of PVC?
    If it is a thick walled hose it is probably flex pvc and can be found at most good hardware and plumbing supply stores. It uses standard pvc cement and fittings.
  1. popped backwash hose near end of hose
    By Gretzky99 in forum Pool Equipment & Operations
    Last Post: 05-22-2013, 10:30 PM
  2. Hose for chlorinator
    By essikr in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-17-2008, 02:41 PM
  3. Hose
    By jrv331 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-03-2008, 05:45 PM
  4. Need Help with a hose
    By IMherDad in forum Pool Equipment & Operations
    Last Post: 07-07-2006, 08:36 AM
  5. How to fix hose from leaking at end
    By nicole12 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-31-2006, 11:07 AM
