Re: Help Help Help , New liner bead appears to be to long!!
thanks, I did manage to get it on. I kept pulling half of the extra material to next section, then half of that to next section etc. had to keep taking sections on and off for about 2 hours but eventually I got everything hooked. There was some wedge type pieces from old liner that appeared to hold liner in track so I put those back. I also picked up some mini clamps at HOme depot for about 20 cents each and they fit perfectly over the bead and bead recepticle so Iclipped a bunch of those on as well. Hope it holds , thanks again
round AG pool
