Thread: Pool enclosure
    Jul 2012
    Virginia
    Default Pool enclosure
    I am having a pool enclosure built. The contractor says that regular wood is okay. I was wondering if it should have pressure treated wood for the structure and/or the exposed roof trusses. Should the windows and doors be vinyl? What is the safest way to install electrical outlets for fans, radio, dehumidifier, etc.? What is the best material for the interior insulation and walls?
    Default Re: Pool enclosure
    Hi Bob,
    I'm not the one who can answer these questions, but there are others who will chime in shortly, I'm sure. In the meantime, though, you can use the google search link in my sig to search for other similar questions throughout the forum and archives.
    Edit: when newer members write posts, they go into a moderator queue to wait for approval to be put on the forum. It's sometime inconvenient, but is part of the process Ben has in place to discourage spammers/hackers. Usually one of us is on the forum all the time, though, so you shouldn't have to wait long to see your post. That's why you didn't originally see your other post. So..I deleted the duplicate, and that way others can respond to you, here.
  1. Cost and/or advise for screen enclosure in central FL wanted
    By mshumack in forum In-Ground Pool Construction and Repair
    Last Post: 11-08-2006, 04:33 PM
