Thread: Newish epoxy paint peeling - concrete pool
    Jul 2012
    Langhorne, PA
    Default Newish epoxy paint peeling - concrete pool
    Hi All,
    I have a 1972 concrete pool and had it painted with Olympic Zeron epoxy, there were a lot of missed spots and after numerous calls the guy came out to paint over, so of course after one swim season the 2nd coat is peeling big time, I assume the first coat was not etched. Now what? The guy is out of business. Do I sand-blast everything, acid etch and coat again?
    Mike
    Default Re: Newish epoxy paint peeling - concrete pool
    Yours sounds like a question for Pooldoc or one of the others with some construction experience. I'll alert them to look into this thread to see if they can help.
    Quote Originally Posted by MJMPiano View Post
    Maybe not everything. But your new coat is only as sound as what it's attached to -- if you paint over unsound old paint, you will have unsound NEW paint, too.
    Sorry. I've used Zeron many times. It's not hard, but it is picky, and many contractors don't 'do' picky. I never had a problem, but I've seen many bad jobs here locally.
    moved thread where it should go -- you can post again now. Sorry! Ben
