Results 11 to 14 of 14
Thread: Algae eating my lunch!
    Default Re: Problem replying to a thread
    Your membership is upgraded now.
    1. Eradicating black algae may, or may not be possible. Often it's gotten down into the concrete in places you can't reach. Once you have black algae, you'll always have to be on guard. The only way I know to surely eradicate it is to refinish, with either new plaster or epoxy paint.
    + First step: pressure wash the pool, but NOT with so much pressure you damage your pool.
    + Next, scrub with TSP, and then rinse and remove.
    + Finally, wash down with FULL strength 6% household bleach. Expect that your clothes will be damaged; but wear gloves, rubber boots and glasses. Be VERY careful to make sure there's nothing in the pool -- bleach can create dangerous fumes with many chemicals. A little left over TSP won't hurt, but get out of the pool immediately if you start smelling fumes. I'd do the sides and shallow area first, and then arrange a ventilation fan blowing into the deep end, just to be safe. Have someone watching you -- someone who's strong enough to hold their breath and drag you out! -- while you work the deep end.
    Each time bleach gets on you, it strips a top layer of skin. The first few times, that's not a problem. But it can become one. So, don't let that happen while you're working with bleach.
    Last edited by Watermom; 07-28-2012 at 04:07 PM. Reason: removed irrelevant sentence after threads were merged
    Jul 2012
    Louisiana
    I am not familiar with this stuff- what is TSP?
    Sorry-should've googled before asking- trisodium phosphate!
    [ posts combined by moderator ]
    Jul 2012
    Louisiana
    Red face Re: Problem replying to a thread
    Thanks, PoolDoc! I am gonna start the process tomorrow. My test kit should be in this evening. Hopefully by tomorrow night I can start refilling. I will post again then to ask about what to add- i'm sure i'll need calcium cuz i have plaster, and will need to know how much salt to start with! I finally feel like i see a light at the end of the tunnel!
    good!
  1. Chlorine eating pool
    By jomars in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-08-2011, 08:01 PM
  2. Man-eating flies
    By AnnaK in forum Pools, Pets and Creepy Critters
    Last Post: 07-11-2007, 10:17 AM
  3. can something be eating CYA??????
    By carolynn in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-08-2007, 01:39 PM
  4. Bleach at Lunch?
    By nanniesrock in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-09-2006, 06:24 PM
  5. Help something is eating my chlorine
    By sierrasmom in forum Dealing with Algae & Slime
    Last Post: 05-31-2006, 03:58 PM
