Thread: Wrinkle in deep end in liner
    Jun 2012
    Pittsburgh
    Default Wrinkle in deep end in liner
    The deep end of my pool liner is wrinkling. It is only 5 years old. The pool guy came out and said it was tight and hard so didn't seem to be water and we are not losing water. He thought it might be from chemical imbalance at some point. I have been using the BBB method along with auto chlorinator with tri-chlor, could this impact the liner at all?
    20'x40' rectangle 30K gal IG vinyl pool; skimmer tabs and trichlor feeder; hayward DE filter; pump; 24hrs; ordered k-2006 not recevied yet. aquacheck pool kit is what I currently have; utility water; summer: solar; winter: mesh; ; PF:4
    Default Re: Wrinkle in deep end in liner
    What have your pH readings been like. Trichlor is very acidic and will drive pH down. Low pH can cause liner problems such as wrinkling.
    Jun 2012
    Pittsburgh
    i test almost daily and ph has been between 7 - 7.6. could it have happened over the winter when chemicals were way off, it has been there but I am not sure if it has gotten worse or not and not sure if I should be concerned about it or not - thanks
    Do you know what your pH reading was when you opened the pool up this spring?
  1. Help Help Help!!!.....liner out of track all around deep end of pool!!!
    By heatherc in forum In-Ground Pool Construction and Repair
    Last Post: 07-24-2012, 10:10 PM
  2. ground water caused major wrinkle
    By dave24 in forum In-Ground Pool Construction and Repair
    Last Post: 04-29-2012, 04:42 PM
  3. Vinyl Liner Detached at Deep End
    By Jward in forum In-Ground Pool Construction and Repair
    Last Post: 03-22-2012, 08:36 PM
  4. 1 year old liner faded in deep end
    By topnotch in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-06-2007, 07:20 PM
  5. liner has sunk 4 - 6 inches in deep end corner
    By [email protected] in forum In-Ground Pool Construction and Repair
    Last Post: 06-30-2006, 07:40 PM
