Thread: Wrinkle in deep end in liner
    Jun 2012
    Pittsburgh
    Default Re: Wrinkle in deep end in liner
    i test almost daily and ph has been between 7 - 7.6. could it have happened over the winter when chemicals were way off, it has been there but I am not sure if it has gotten worse or not and not sure if I should be concerned about it or not - thanks
    20'x40' rectangle 30K gal IG vinyl pool; skimmer tabs and trichlor feeder; hayward DE filter; pump; 24hrs; ordered k-2006 not recevied yet. aquacheck pool kit is what I currently have; utility water; summer: solar; winter: mesh; ; PF:4
    Do you know what your pH reading was when you opened the pool up this spring?
