Please Help.. Persistent Green Pool.
It's actually a very pleasant light bluish green.. but it isn't the crystal clear blue that it was before we had all this rain.
And I'm a new pool owner and I'm lost.
I went to the pool store and they offered me 50 dollars in chemicals.. I already have enough chemicals to start my own store.
So here are my readings:
FAC: .5
TAC: .5
PH: 7.2
TA: 60
CYA: 30
I can see that my Chlorine is bombed out and my PH and Alkalinity are a bit low.. I also see that I could probably up the CYA a little.. but it isn't at a critical point.
I would LIKE to try the BBB method but I don't even know where i would start?
