Thread: Filter pressure rising after 3-4 hours
    Jul 2012
    Pennsylvania
    Default Filter pressure rising after 3-4 hours
    My filter pressure rises after about 3-4 hours of installing new DE or bumping it. I acid washed the filter today and it still rose from 14 to 20 after filtering for about 3 hours. The pool is cloudy and I had to adjust the hardness and the alkalinity, but anyone have any ideas.
    Default Re: Filter pressure rising after 3-4 hours
    Post a complete set of current water testing results taken with a drops-based kit -- no test strips. Have you recently had algae? If so, the cloudiness may be dead algae being filtered out which will cause the pressure to rise. Also, tell us exactly what all you have added to the pool -- meaning ingredients and not just 'shock.'
    In addition, please put your pool's information into our pool chart to make it easier for someone here to help.
    Pool Chart Entry Form
    Welcome to the Pool Forum!
    Quote Originally Posted by Planguy21 View Post
    Did you acid wash, before you cleaned it with detergent? If so, you may have ruined the grids. Check your filter manual. Sorry!
    However, DE filters can ALSO rise in pressure rapidly because they are WORKING -- if the filter is effectively removing whatever's in the water, it may be operating 100% normally.
    . . . Also, live algae blinds off, or plugs DE filters very, very quickly sometimes in minutes.
    So . . .
    1. Read your filter manual's cleaning instructions.
    2. Get a good testkit, and then tell us what's in your pool. (Links below -- 'guess'-strips don't count!)
    3. Tell us WHAT your water looks like and WHAT you've been putting in it.
    + Here are links to the kits we recommend:
    HTH 6-Way Test Kit @ Walmart
    Taylor K2006A (3/4 oz bottles) @ Amazon
    Taylor K2006C (2 oz bottles) @ Amazon
  1. new intex pool - how many hours should filter run daily?
    By springtunnel in forum Pool Equipment & Operations
    Last Post: 07-19-2011, 11:41 PM
  2. Pressure rising quickly
    By dsimpson in forum Pool Equipment & Operations
    Last Post: 06-29-2011, 11:01 PM
  3. Sand Filter Pressure Rising Quickly
    By dborg in forum Pool Equipment & Operations
    Last Post: 06-09-2011, 02:12 PM
  4. DE Filter pressure rising high, no water in pump
    By fog80 in forum Pool Equipment & Operations
    Last Post: 07-01-2010, 07:22 PM
