I have a 4 month old gunnite pool, 20,000 gls with brownish stains on the walls, bottom and steps. I suspect they are from a copper algaecide I foolishly put in several weeks ago. The stains responded to the vitamin c test and to dry acid pH reducer in a sock, so I opted for an aa treatment.
Numbers this morning via Taylor 2006A kit:
FC 3
CC 0
pH 7.4
TA 90
TH 175
CYA 70
Chlorine was trending down nicely the last few days with none added; FC was 8 on July 15. CC has been 0. Added thiosulfate this morning to wipe out the chlorine. Cartridge filter removed. Left pump off while putting in aa so it could sit on steps and swimout for a while. Came back 1 hour later and pool water was clear GREEN. What? Added 2 quarts of Jack's Magic Pink stuff and started the pump, no filter.
FC now is 0 and pH is about 6.8. The pool now, 3 hours later, is still a clear but darker green. Is this an algae bloom? I don't think it is as there was no sign of algae prior and the water is clear, no clouding. I plan to start adding back chlorine via bleach tomorrow I guess. Could this be copper or iron releasing into solution causing the water coloration? One more thing, I added a Culator on Monday and this morning (Wednesday) it had turned blue indicating that it was binding copper per their literature. At this point some stains have lifted but not a miracle yet. Plan to brush tonight and hope for better results by morning.
Surely hope to hear from the aa treatment experts on here. Tried to post to stain removal thread but had to go here first since I am new. Great forum; I have learned a lot as a lurker.
