Thread: What reagent with this comparator for chlorine?
    Lehigh Valley, PA
    Default What reagent with this comparator for chlorine?
    I have a comparator that's about 4" x 4", in the pinks for pH and in the yellows for CL/Br. The Cl goes up to 5 on it. Which Taylor reagent do I need to test for Cl?
    I normally use the DPD-FAS process but my FC stays pretty much the same (3 - 5 ppm) and I could save on powder if I just went with the drop testing. Unfortunately, I cannot remember which drops that would be
    Default Re: What reagent with this comparator for chlorine?
    Anna, what water sample size does the chlorine test use on that comparator? How about for the pH test?
    Lehigh Valley, PA
    I really can't answer that, WM. The tube gets filled to the line, the water doesn't get measured by volume.
    After doing a little online research I'm pretty sure what I have is the Leslie's Deluxe OTO kit which takes 5 drops of R-0600 for the chlorine and 5 drops of R-0014 for the pH.
    jwhouse is offline Registered+ Thread Analyst jwhouse 0
    Jun 2012
    Southeast Louisiana
    If it is the Leslie's Deluxe OTO kit, it is actually the Taylor K-1003 which is rebranded for Leslies. I have the exact same kit. Here is the link for the kit at Taylor: http://www.taylortechnologies.com/pr...D=1&KitID=2452
    BigDave's Avatar
    Does the comparator have two little square tubes like this? Then - Yep, R-0600 OTO and R-0014 pH.
    Lehigh Valley, PA
    Yes and yes
    Thanks!!
  1. saving on reagent for chlorine testing
    By keastman in forum DPD-FAS based testing
    Last Post: 04-07-2012, 04:46 PM
  2. DPD Reagent? For testing Chlorine
    By Digger in forum DPD-FAS based testing
    Last Post: 07-20-2011, 12:53 PM
  3. CYA Reagent
    By drumr in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-06-2007, 07:52 PM
  4. Where to buy reagent refills
    By dhale63 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-17-2006, 02:11 AM
  5. cya reagent
    By pedsrn in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-15-2006, 10:05 PM
