Re: New to Pools/Spas
I had a chance to try out my K-2006a kit last night and again this morning to test the in-laws pool. They had originally filled it last weekend and left city water in it all week with very little to no chlorine in it. The bottom felt a little slimy on 7/25, so enough shock plus was added to get to 20 ppm FC (estimated via poolcalculator at 1 lb of dichlor).
Date - Time
7/26 - 7:30 pm
7/27 - 6:30 AM
pH - 7.8 - 7.6
FC - 14 - 13
CC - .5 - n/a
TA - 80 - 120
CYA - <30 - Disappeared at the VERY top of the tube ~20
CH - 20 - 20
pH was overshot with Borax, originally tested at <7.0 and added Borax 3 times to get to 7.8, after 2nd time adding Borax, pH read 7.0. Apparently I got impatient and tested too soon as I added less Borax the last time.
FC was at 6 ppm and dichlor was added (after pH was "balanced") to get to shock level (again) and see how much FC was used overnight.
CC wasn't checked this morning (was running late for work and ran out of time to test).
TA was adjusted using Baking Soda, added twice. First reading was 50 ppm and then 80 ppm (all wasn't in solution and mixed well yet apparently either), no further additions were made.
CYA has been added via dichlor (Aqua Chem Shock Plus, 58.2% Sodium Dichlor..., 41.8% other ingredients)
CH have not added calcium, but have calcium plus (iirc) on hand if needed.
