Results 1 to 10 of 13
Thread: Need quick confirmation that I'm dealing with iron
    Default Re: Need quick confirmation that I'm dealing with iron
    Put a little granular chlorine on a spot.
    If it's mustard algae, the chlorine will kill it. If it's iron, it won't have much effect.
    Minnesota
    there are no "spots". I can easily brush the orange away -- it acts like algae. A little slick/slimy if you run your hand over it, but it disappears in a cloud. But if it WERE algae, I'd assume my chlorine regimen would have gotten rid of it.
    Quote Originally Posted by jenmenke View Post
    Mustard algae can be chlorine resistant.
    Do the Pool Chart; do the chlorine test I mentioned.
    + It's much easier to answer your questions, when we have the details about your pool in one place. We often 'waste' the first few posts back and forth collecting information. So, please complete our new Pool Chart form -- it takes about 30 seconds, but will save much more than that.
    Pool Chart Entry Form
    Minnesota
    I did do the pool chart. Odd. I guess I'll do it again
    Minnesota
    I'm not sure I understand: you mean sprinkle granular chlorine on to the wispy, easily brushed away orange and then try really hard not to disturb it? Since I only use bleach, I don't have any granular chlorine. Can I crush up a puck? I think I have a few of those. Let me know
    I hadn't looked for your chart; I will. If it was there, it still is.
    But, a small piece of trichlor will work fine. You can lower it into place with a thread. Just don't leave it there overnight, or anything like that.
    Minnesota
    OK. I put a tricolor tablet directly on top of a corner that had some orange starting to show and two hours later it was mostly gone. So that's algae, and not iron, right? So now what? My guess would be that I didn't keep the chlorine ppm high enough for long enough?
    You are correct.
    Mustard algae can be eliminated by brushing + very high chlorine, and then continuing high chlorine and brushing after it all seems to be gone.
  1. Newbie - has question or more specifically needs confirmation - pool install is now!
    By rannrich in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-23-2011, 03:31 PM
  2. New Pool Owner With High Iron Manually Removing Iron
    By labdi01 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-18-2010, 03:56 PM
