Thread: New SWCG user.
    Jul 2012
    Thumbs down New SWCG user.
    I setup my 23 foot round above ground pool with a Hayward Goldline AQ-TROL-RJ-TL AquaTrol Above-Ground Pool Return Jet pool Chlorinator.
    Running 6 hours (3 in morning 3 at night) 60% output on the SWCG.
    Even before switching to salt i would get Green-like algea on the sides and bottom of the pool.
    I can scrub with a rag and filter/shock the pool and it goes away.
    Since switching to Salt it appears the issue still occurs once the Free Chlorine level drops below 3.
    I tried to get my levels into to ideal values but i'm still not able to. Pool is clean with no other issues.
    Last check of level are as follows
    Hardness = 0 (Do i even need to worry about this ??)
    PH = 7.0 (on the lower end)
    FC = 10 (shocked yesterday) Has always been fine only level I can manage
    ALK = 60-70 added 3 lbs of baking soda very little change (added 3lbs before switching to salt as well) can't get this to higher levels
    CA = 30-40 Added 5lbs before switching to salt level hasn't changed
    Salt = 3200-3400 (stable)
    Any suggestions on the green algea.. is it just lack of chlorine.
    Thanks for your help.
    Default Re: New SWCG user.
    Quote Originally Posted by masssilverf150 View Post
    Even before switching to salt i would get Green-like algae on the sides and bottom of the pool. I can scrub with a rag and filter/shock the pool and it goes away.
    Sounds like mustard algae; keep your chlorine ABOVE 3.0 100% of the time.
    If you switch get a DPD-FAS testkit, so you can actually *measure* levels above 3, you can probably fine tune it more than that. (We call them 'guess'-strips for a reason!). Check out the test kit link in my signature if you are interested: get either the K2006 OR the K1515. And no, they aren't available locally.
  1. New User
    By hazellee116 in forum Pool Chemistry for Intex-type Pools
    Last Post: 08-13-2012, 04:18 PM
  2. New User
    By 2beermike in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-28-2012, 03:59 PM
  3. New user looking for above ground pool reviews, ratings n user pics of pools
    By Piggiesinlove in forum In-Ground Pool Construction and Repair
    Last Post: 07-19-2011, 06:08 PM
  4. Anthony-new user--help selecting new SWCG
    By MUTTS in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-05-2011, 09:22 PM
