Results 1 to 10 of 11
Thread: Drain pool or add 77 lbs of shock - other options?
    Jul 2012
    Kansas
    Default Re: Drain pool or add 77 lbs of shock - other options?
    I ordered and received the dichlor from Amazon: Kem-Tek Dichlor 22 lbs. How do I add this - a little each day or a lot initially or ?
    We also purchased new large and medium filters. The medium filter has arrived but the large filter is estimated to be delivered next week. I had cleaned our existing filter with a special soap purchased from the pool store about a month ago, but we decided that the filters probably needed replacing, possibly because last year my husband used a power washer on them. Regardless of the reason, the filters don't seem to be working well.
    12yr old 18x36 IG 22.5Kgal vinyl pool; 2spd pool pump; StaRite Sys3 S7M120 cartridge filter; 24hr/day on LO; HTH 6-way; utility water; PF:5; net-dev
    16'x36' rectangle 22.5K gal IG pool; trichlor inline feeder; Starite System3 S7M120 cartridge filter; Magnetek Century Two Speed, HP 1.0/.12 pump; 24 hrs on lowhrs; I was using test strips (hth 6-way test strips) and going to pool stores. See notes in comments below for values obtained after purchasing hch 6-way test kit.; utility water; summer: ; winter: ; iPad; PF:5.3
    2 lbs (4 cups) at a time will add 5 ppm chlorine doses to your pool, and 4 ppm CYA doses. Just use the dichlor to add chlorine.
    Power washers will definitely destroy cartridges. You don't need a special soap; the cartridge makers all recommend TSP. Full instructions here:
    http://www.poolforum.com/pf2/showthr...ut-Damaging-It!
