Thanks! I just tested my fresh water for ph and it is reading between 7.8-8.0. This is probably a stupid question, but is that normal for fresh water? And if so, am I correct in assuming I should not add any borax at this point? I will retest after adding salt and stabilizer.
Also, will Pristine Blue "residue" on my filter cartridges cause an adverse effect on my pool chemistry? Switched back to swcg...cleaned filters as best I can...
