Thread: Ground Preparation/Tree Removal
    Cleveland, OH
    Default Re: Ground Preparation/Tree Removal
    Where will this hole fall in relation to the pool. Will the liner sit over this hole?
    I had a similar situation when I installed and it fell under my liner.
    Since its a relatively small area fill it with loose dirt and use a hand tamper to pack it down. I would do it in layers. You can get some real force with a hand tamper so you can get it packed nicely.
    duraleigh Guest
    Dusan,
    Sand will work nicely as well. It is self-compacting and very easy to level.
    dis_250 Guest
    Thanks for replays.
    The hole is in the middle of round section. It will be under the linear.
    I was also told to use crushed limestone and to put some sand on the top of it.
    I don't want to be surprised once when the pool is full of water.
    Cleveland, OH
    In the middle. Thats perfect. I would just fill and pack with sand.
    JJ in Tx is offline ** No working email address ** JJ in Tx 0
    Spring, Texas
    tamp the sand or what ever you use down tightly.
    Like maxx said "layers", if you do it a bit at a time it will compact easier and better than if you fill the whole hole and try to do it.
    JJ
    Hi, It's been all good advice so far. The key is to water and pack several times before installing a liner over it.
    Good luck, Dennis
