Thread: Goldline Salt Generator DEAD
    Jul 2012
    Texas
    Default Goldline Salt Generator DEAD
    I'm looking for troubleshooting suggestions for a Aquarite Goldline generator system. I have no display or lights and know the following:
    - I replaced the main circuit board because the Hayward folks told me this was the most likely fix if the fuse was good. So I have a new board with fuse installed.
    - This system has no external fuse, so uses the fuse on the board.
    - I have power to the main circuit board.
    Any thoughts on what to do to try and isolate the issue. I don't perceive there to be but 2 other components: 1) the small circuit board with the display on it and 2) the transformer. But I don't know how to determine if one or the other of these is at fault. Or, if there are any other possibilities.
    One final note. This system is "out in the country", so I have limited access to it - 1/2-day round-trip travel time.
    Default Re: Goldline Salt Generator DEAD
    Hi Thom49. Sorry I can't offer you any advice about your question but just wanted to stop by and welcome you to the Pool Forum! Hopefully, someone with some knowledge of this unit will be along shortly who can help you, though. I'm not sure what you'll find, but in the meantime, use the Google Search in my signature below to see if you can find any prior threads about this piece of equipment.
  1. Goldline AquaRite Salt Chlorinator Circuit Board
    By maculver in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 11-14-2011, 10:12 AM
  2. No Power Light on Goldline Chlorine Generator
    By mirobbi in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 10-04-2011, 05:46 PM
  3. Goldline says salt too high?
    By shave in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-22-2010, 01:07 PM
  4. Salt for non salt generator pool
    By graciec in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-04-2007, 01:26 PM
  5. AquaRite by GoldLine Salt Chlorinator
    By s0undone in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 03-30-2006, 12:23 AM
