Thread: Loosing suction
    BigDave's Avatar
    Default Re: Loosing suction
    Is the pump losing prime? Is there air in the pump basket?
    Shifty is offline Registered+ Thread Analyst Shifty 0
    Jun 2012
    Pennsylvania
    Hardley,
    When you turn on your pump, the top to the pump basket will tighten as the pressure builds. Once the pressure levels off, try and loosen the top to the pump basket slightly so a little bit of air can get in. A little bit of air will help circulate the water in the pump basket. If you loosen the top too much, you will lose prime.
    Once you play around with how much to loosen the top, take notice of the top's position for future reference. I mostly need to do this when I hook up the vacuum to the skimmer.
    American Titan SS DE Filter; Multiport; 18'x36' grecian 24K gal IG krystalkrete (super blue) plaster; BBB and trichlor pucks for CYA; Hayward SP3400VSP Ecostar; Taylor K-2006; The Pool Cleaner Auto Vac (4 wheels)
    Jul 2012
    northern OH
    yes there is water in the pump basket. I will try loosening the sight glass top on the pump basket in the morning to see how that works.
