Results 1 to 10 of 23
Thread: Low Chlorine Problems
    Jul 2012
    Nebraska
    Default Low Chlorine Problems
    OK I'll start by saying I'm a newbie. I'm not sure how many details I can give, or should give, but here we go.
    I told my mother-inlaw I would try to be her pool boy this spring, as she is gone a lot, so I have been trying to learn from your website for the last couple months off & on.
    She spent lots of $ dumping in whatever the local pool guy told her over the past 20 years. I have been trying to convince her the BBB method will save her $ & have a nicer, easier to maintain pool. It has worked pretty good up until recently, I can't seem to keep the chlorine levels up & now have an algae problem.
    The pool is a 16,000 gal. in ground fiberglass pool, it has a chlorinator, she has been using for years, so the CYA is high, over 100, have gotten mixed readings from the local dealer, ranging from 107-168. He says his machine won't give a accurate reading if the chlorine level is above 3, well from my reading, I have been trying to keep it around 8.
    I shut off the chlorinator early on, to save $ on sticks & stop raising the CYA, but the last week have put in 4 gallons of bleach & TC still below 1. The mother-inlaw dumped in a couple bags of shock last night. Will see if that helps? Or was the right choice?
    But she just did it & told me later, because I haven't been being a good enough pool boy.
    LoL Help Please
    Default Re: Low Chlorine Problems
    I'll try to look at this again tomorrow but it's getting late, so I'll post some relevant snippets that will help get you started.
    Ben
    + Get a cheap OTO (yellow drops) / phenol test kit, or if available at YOUR Walmart (check availability), get the HTH 6-way DROPS test kit, which is compatible with the Taylor K2006. Test the pool as soon and you can, and post the results. If you get the 6-way kit, ALSO test the water you FILL the pool with, especially if it's a well, and post THOSE results as well. (The HTH is the best available kit you're likely to find locally, but it's not the K-2006. It can only provide rough measurements chlorine levels above 5 ppm, and it measures "TOTAL" hardness, rather than "CALCIUM" hardness, which is not ideal.)
    + Having a good test kit makes pool care easier for EVERYONE. A good test kit means a kit that can test chlorine from 0 - 25 ppm, pH, alkalinity, calcium hardness, and stabilizer with reasonable accuracy. Test strips (AKA 'guess-strips' ) do NOT meet this standard. Some pool store testing is accurate; most is not. The ONLY way you'll know whether your pool store is accurate or bogus, is by testing accurately your own self. On the other hand, pool store 'computer' dosing recommendations are NEVER trustworthy -- ignore them. They are designed to sell more chemicals than you need, and WILL cause many pool problems.
    + We recommend the Taylor K-2006 test kit, which meets the requirements above, for many reasons. The HTH 6-way drops kit is a great starter kit, and is compatible with the K2006 (it's made by Taylor). There are a few alternatives; for example Lamotte makes an FAS-DPD kit that's OK -- but it costs 3x as much. But, we're not aware of any test that is better, and since we are all familiar with the K-2006 (and can help you with it) we recommend it exclusively ( Test kit info page )
    One caution for the 2012 season: Amazon does not stock the kits directly. So when buying at Amazon, Amato is our current preferred seller. However, they often don't list enough stock to last the whole day, so try order mid-morning. You should expect a delivered cost under $60 for the K2006A and under $95 for the K2006C. If you can't find that, wait a day.
    + Here are links to the kits we recommend (you can check local availability on the HTH kit, using the Walmart link):
    HTH 6-Way Test Kit @ Walmart
    Taylor K2006A (3/4 oz bottles) @ Amazon
    Taylor K2006C (2 oz bottles) @ Amazon
    + It's much easier to answer your questions, when we have the details about your pool in one place. We often 'waste' the first few posts back and forth collecting information. So, please complete our new Pool Chart form -- it takes about 30 seconds, but will save much more than that.
    Pool Chart Entry Form
    Jul 2012
    Nebraska
    Thanks for the reply, I read more today & expected your answer to be lots of chlorine. I did try to fill out the pool info. Under my ID if it took? The pool readings this evening are:
    Fcl:2.5
    Tcl:3.13
    PH:7.2
    Alk:170
    CYA:High- too high for my reader 125+
    Pool store says total hardness around 300
    From looking at the best guess chart I'm guessing I need to have my Fcl around 2525 to shock effectively. I added 1/2 box borax & 3 Gallons 6% Cl. Will recheck tomorrow, & try to keep Cl up that high. I can't test real effectively that high without having to dilute & multiply.
    Thanks again
    Jul 2012
    Nebraska
    Readings this morning:
    Fcl:4.54
    Tcl:5.62
    PH:7.3
    Alk:182
    Added another 1/2 box borax & 3 more Gallons of 6% Walmart bleach
    People look at you funny when you stroll through the store with 12 gallons of bleach & 3 boxes of borax in your cart. Either I'm a serious laundry man, or making some kind of terrorist concoctions
    You really need to bite the bullet and order a good kit --- Taylor K-2006. With a CYA level that is through the roof like yours, you will have to run extremely high chlorine levels (per the Best Guess Chlorine Chart in Ben's sig above). The HTH 6-Way kit and an OTO kit only measure chlorine to 5 and aren't going to help you.
    You did the right thing turning off the chlorinator but you are not adding big enough doses of bleach to accomplish anything since the CYA is so high. In your pool, each gallon (4 qts.) of 6% bleach will add just under 4ppm of chlorine. As you can see from the Best Guess Chart, your shock level is going to be around 25ppm, so the 3 gallons you added is not taking it high enough. Keep adding bleach every time you test and get back to 25ppm. Continue to do so until you can go from sundown one evening to within 2 hours of sunrise the next morning without losing more than 1ppm of chlorine and the water is clear. Then, keep it high for one additional day. After that, you can let the chlorine drift down but must always keep it between 8-15 ALL the time or you'll constantly be fighting algae. No more trichlor pucks nor any type of dichlor shock powder in this pool!
    Your pH is fine where it is so don't worry about more Borax at this point.
    Order the good kit. In this pool, it really isn't an optional item but a critical one or else you'll have a very difficult time managing this pool.
    Hope this helps. Good luck.
    Quote Originally Posted by nscclukas View Post
    My wife just cracked up, when I read this to her. (She's helping with some forum stuff right now, and is in the office with me.) She -- having been sent to the store on a MISSION by me -- commented, "He should try checking out when you bought the entire stock of 24 boxes of borax from a single store!"
    Jul 2012
    Nebraska
    Maybe I'm wrong? But I was thinking on 16,000 gallon pool 1 gallon Cl would raise 8ppm. We just recently bought the Lamotte Color Q 7 digital test kit. It is a liquid test kit, works great, no more guessing at colors, it gives you a # to go by. The mother in-law loves it, she didn't bother to check her readings before very often because it was always a guess what the color was. She just took samples to town & let the pool store tell her what she needed. For 20+ years, imagine how much $ she dumped into the pool. The local pool store will probably go out of business now that I've banned her from going there
    One gallon of 6% bleach in this pool would add about 3.8ppm of chlorine.
    I'm not familiar with that kit or how high of chlorine readings it can read so I can't comment on that. Someone else may know more about its capabilities and limitations.
